Fitting T1R Decat
Old Aug 13, 2006 | 04:56 AM
S 2 Fizzle's Avatar
Default Fitting T1R Decat
Finally getting round to fitting my decat pipe!
Couple of questions first though, sorry if they are a bit daft!
1 Do i need to replace the domed gasket at the forward end, between cat and exhaust, for use with my decat?
2 Do i need to utilise and if so do i need to replace the rear circular gasket between cat and exhaust for use with my decat? Bit confused as a metalic gasket has been supplied at this end that forms the profile of the joint. Do i just use this? Also do i need any sort of compound to seal any of the joins or are the gaskets suficient?
3 Should the forward bolts through the springs be replaced and is the torque setting 22 Nm / 16 lbf ft ?
4 Is the O2 sensor torque setting 44 Nm / 33 lbf ft ?
Any help much appreciated
Old Aug 13, 2006 | 04:59 AM
S 2 Fizzle's Avatar
Sorry bout 2 posts, first one appeared not to have been sucessful! Can someone kill one of them off ?!?!?!
Old Aug 13, 2006 | 05:39 AM
Paper Lawyer's Avatar
I ran my T1R test pipe and exhaust quite happily without buying any replacement gaskets. I recall that the gasket which came with my exhaust and testpipe was metallic and perhaps a better shape?
Old Aug 13, 2006 | 06:01 AM
markS2kcU's Avatar
1. Don't really need to change it, I never have.
2. Just use the metal gasket that came with it, Mines gasket free.
3. If the old spring/bolts look ok use them. I don't torque them, just get them as tight as I can laying on my back.
4. As above using the torque method. Plus how do you get a socket over the wires?
5. Stop messing about and get it on.
Integra21
Aug 20, 2006 11:31 AM
shadykit
Aug 20, 2006 08:53 AM
S 2 Fizzle
Aug 13, 2006 07:21 AM
s2konroids
Mar 13, 2006 10:48 AM
CrAzYNeSs
15
Apr 13, 2005 04:58 PM
