Fluid leak
A small puddle is appearing behind drivers side wheel. I'm thinking it might be a split in the washer fluid reservoir or associated pipework. However it doesn't smell of washer fluid - it just has the consistency of water.
Before I take off the arch liner to have a look-see anyone got any other thoughts ? There does seem to be a hole under there which I assume is a drain of some sort.
Is there anywhere rainwater could pool up behind the wing....?
Andy
Andy
Hi Andy,
Got mine from aceparts_uk. using their ebay listings. Quoted as being for a Honda S2000 windscreen washer pump. Cost £5.32. Fitted perfectly.
Hi Andy,
Thanks MI5 - ordered and on its way....good find. Did it come with the grommet included - its not clear from the description
gptoyz
Apr 5, 2014 09:24 AM
Danwolski
Jun 29, 2012 11:49 AM
