Use the same fluid pump?
Old Jul 14, 2009 | 09:55 AM
evil MS3's Avatar
Default Use the same fluid pump?
Is there any issue using the same fluid pump for filling the trans and the rear diff or should I buy one for each? perhaps a pump clearing the previous fluid w/ the new fluid would be enough?
Can these be stored to be re-used? Best way?
I'm planning on using Honda trans fluid and mobil1 75w90 LS, any issues?
Old Jul 14, 2009 | 10:12 AM
spets's Avatar
I used the same one for both.
Just run the 2nd fluid through the pump a bit to clean it out and you should be ok. Whatever is left and gets in will be so diluted it don't affect anything.
Old Jul 14, 2009 | 11:32 AM
JackS's Avatar
I went through this a couple of months ago. For the trans., buy about 4 feet of heater hose and thread it into the engine bay, insert a funnel and your done in 5minutes. I did use a pump for the rear end and what a mess that turned out to be. If you do use a pump, be very patient and pump slowly or the pressure will cause the tubing to seperate which is the problem I had and the resulting mess. Next time I'm going to use a large rubber bulb syringe for this task.
Edit "1/2in heater hose
bikky
Aug 19, 2014 03:22 AM
andy2000
Jul 21, 2014 11:16 AM
andy2000
Car Talk - Non S2000
Jul 29, 2011 08:33 AM
gtg749m
Apr 27, 2009 08:51 AM
jacksonjw81
Aug 10, 2008 02:46 PM
