Fog Light Bracket Replacement
Old Jul 30, 2012 | 03:28 AM
eSeM's Avatar
Default Fog Light Bracket Replacement
The brackets holding my fog light have corroded and snapped. Is there an easy way to get access to the fog light to fix it via the number plate surround or is it a case of completely removing the rear bumper?
Old Jul 30, 2012 | 12:30 PM
loftust's Avatar
Search!!!
[/Gaspode]
Old Jul 30, 2012 | 12:31 PM
loftust's Avatar
FWIW, it would be easier to remove the bumper
Old Jul 30, 2012 | 01:46 PM
astage's Avatar
It's well worth the effort to remove the bumper, but if the fog-lamp fixing have rusted through, be prepared to find considerable corrosion of the number-plate surround fixings, the number-plate lamp screws and the bumper beam itself. Since it's hidden away, Honda apparently didn't bother rustproofing the steel work, so do buy a tin of rust treatment in preparation. Plus, you'll get the chance to remove all the gravel that has collected there!
Old Jun 23, 2013 | 02:25 PM
Waggylau's Avatar
Nice to just meet you Mr.Astage, as I'm going to be doing this bracket replacement tomorrow or in the next few days the above advice will be obviously noted and I'll let you guys know how I got on.
Old Jun 24, 2013 | 04:42 AM
CHIPPO's Avatar
Remove bumper, I had trouble getting the 2 fixings out that go through the bottom of the bumper in any case and had to grind them of. Then I had trouble removing the 2 screws that hold the lamp assembly to the brackets and had to drill these 2 screws out. ( these screws also hold the lens on )
I fabricated 2 new brackets from and bit of 1.5 stianless sheet
Old Feb 22, 2014 | 11:45 PM
Nottm_S2's Avatar
I need to do this.. The brackets look pretty small so i dont need much tin right? Just fleabay some?
Old Feb 23, 2014 | 10:28 AM
loftust's Avatar
You won't need much - stainless will naturally be better.
Sent from my GT-I9300 using Tapatalk
frutter
Jul 26, 2015 05:22 AM
weekendwarrior44
Feb 17, 2014 10:38 PM
RODNEY S2000
Oct 13, 2010 11:11 AM
roflitzjinno
Sep 24, 2010 03:24 PM
