Front BSK - Rack spacers
Old Mar 29, 2011 | 12:01 PM
martin j's Avatar
Re the bolts, if you look at/on the head of the bolt there will be a marking if they are high tensile, it will be probably 8.8 or 10 at a guess, this is what you will need as a replacement.
Old Mar 29, 2011 | 01:42 PM
m1bjr's Avatar
Originally Posted by oxhouser
It's on a spline or clamps so you just slacken it off and allow it to sit where it adjusts to, I suppose it might make the angle a bit more acute but I doubt it will make the steering notchy
That is a very worthwhile point for the DIYer.
You must slacken the little pinch bolt on the steering column knuckle to allow it to slide up its splines a bit.
Or you wont EVER lift the rack enough to jam a spacer under it lol
And dont forget to nip it up after. It's an MOT point too naturally.
There is also a metal C clip that carries a rubber hose (lower rad from memory) near one rack mount.
Take it off - IIRC use a 10mm ring spanner and swear at it a bit.
It makes life SO much easier to get the rack bolts back in.
You can refit it after.
Old Mar 30, 2011 | 12:03 PM
Dembo's Avatar
I have some play in my steering, and I've had the rack spacers for about 4 years now. Not saying there's a connection... but I do wonder.
Old Mar 30, 2011 | 11:17 PM
TangoVTEC's Avatar
I had the tiniest bit of play at dead centre following my clutch change. Make sure your uj is nice and tight up the spline, it made a world of difference.
Don't over torque the pinch bolts though!
Old Mar 30, 2011 | 11:45 PM
Dembo's Avatar
Yes it's at dead centre, and I had a whole engine change. Thanks, you might have saved me a load of money if it's that simple - I was looking at getting a secondhand replacement rack.
Old Mar 31, 2011 | 08:19 AM
TangoVTEC's Avatar
No worries.
Simplest thing I can recommend is banging a load of wd-40 or some grease on the splines, and this part is critical; turn the column so that the bolts are facing you (when your under the car) and torque them from the side, whilst lifting/pushing the uj up the spline towards the steering wheel.
Maybe easier with an extra pair of hands.
This will avoid accidentally pushing the uj downwards towards the rack as you lean on it to torque the bolt, which is nine times out of ten the problem people encounter.
DOJOD
Nov 7, 2010 11:11 AM
mattyc
Feb 15, 2010 11:47 PM
nicholasbartleet
Jan 23, 2009 07:57 AM
if lookz kill
Socal Swap Meet
Nov 9, 2006 10:24 AM
oOweEe
Aug 10, 2004 09:20 PM
