Front bumper??
Old Oct 11, 2001 | 10:30 AM
dwrights's Avatar
Default Front bumper??
I'm in the process of taking off the uk model number plate holder. I undid the two 10mm nuts and gave it a good tug but it has another two captive bolts which i think is only got at by removing the front bumper.
Has anybody removed one? Any hidden bolts i need know about?
Did a search but none of the links work.
Old Oct 11, 2001 | 12:27 PM
dwrights's Avatar
14 views so far,somebody must know, surely.
Old Oct 11, 2001 | 02:53 PM
dwrights's Avatar
Leaving work now, i will just have to get under there and ferret around to find those bolts.Laptop's busted at home, so i will catch up with you lot on Monday. Have a cool weekend, i think it will be sunny!
Old Oct 11, 2001 | 03:18 PM
Frenchie's Avatar
Are you putting a sticky one on above the grille? Are you going to remove the H badge? Did this with my ex-wife's MX5 and it looked good. Not so sure about doing it on the S2000 though.
Pete
Old Oct 11, 2001 | 03:38 PM
Frenchie's Avatar
Thinking about it, if I get time this weekend, I'll doctor a photo to see what it might look like.
Pete
Old Oct 12, 2001 | 04:59 AM
abladon's Avatar
You will indeed need to remove the bumper. Its made a lot easier if you put the front of the car on axle stands. Just remember to carefully disconnect the headlight washer pipes or else!!
Otherwise its a fairly easy task. Really need two people when actually removing the bumber. I then filled the holes with resin and stuck the number plate over the top - looked fine.
Good Luck
Alastair
Old Oct 12, 2001 | 05:09 AM
Frenchie's Avatar
[QUOTE]Originally posted by abladon
[B]I then filled the holes with resin and stuck the number plate over the top - looked fine.
Good Luck
Old Oct 12, 2001 | 05:18 AM
abladon's Avatar
I'll scan a picture in and post it over the weekend.
Old Oct 14, 2001 | 09:47 PM
dwrights's Avatar
I am keeping the Honda badge on, and putting a very ilegal 70mm stickt number plate on just above the grill. It looks very mean!
Old Oct 19, 2001 | 02:11 AM
mcc601's Avatar
Any chance of putting up a picture of the stick on number plate ?
And where did you get it from ?
I have been thinking about doing this since I got the car in August and a minor incident with some wildlife has meant that the car needs a new front bumper, so I have the opportunity of not having the numberplate holder put back on by the dealership.
Hope you can let me have the info.
Matt
eddw
Apr 8, 2014 12:29 AM
Fatbloke
Sep 21, 2009 07:53 AM
mark1
Mar 15, 2008 03:18 AM
FISHHEAD
Mar 18, 2006 02:52 AM
vtecIT
May 5, 2005 09:33 AM
