Front Control Arm Bolt HELP
Think putting another nyloc nut on will hold it ok,could even grind it down so the nyloc workings engage with the good thread on the existing.Maybe could even get a slim nyloc also if needed.
Bit difficult without seeing the final results,
cram/torque it up and see
ie you didn't here it from me
Hahaha thanks!
I really don't see how a new, non welded nut, would affect any alignment. Torqued is torqued right?!
Maybe. The nut is welded to the subframe itself rather than the wishbone though.
I'm rather confused by the whole idea of it.
If I can't get the bolt out without resorting to a disc cutter then the captive nut will have to come off! Oops!
Either the nut or the bolt (or both) is stripped. Cut the end of the bolt off as close to the nut as possible. If you are lucky it may then just pull out (with a bit of effort/leverage), or come out with a pull and twist? Once out you can see where the damage is.
Thanks mate, I'm going to have a look tonight.
If it's the nut that's stripped, is there any complication with removing it and replacing? Or will that, as mentioned, cause alignment issues?
s2000maniac
Mar 10, 2014 03:09 PM
chriss.
Sep 22, 2012 07:49 AM
zeroptzero
Aug 30, 2010 08:02 PM
