Front drop links
Old Mar 1, 2019 | 04:02 AM
Brailer's Avatar
Default Front drop links
Service at honda told me I needed to replace my front drop links. Where the best place to get these from. IV looked about and the prices range from £100 each from honda to £15 from eBay. Is this also a DIY job? Looks simple enough but I'd rather a garage slave away at getting the old one of if they are going to be welded on after all these years.
Cheers
John
Old Mar 1, 2019 | 04:13 AM
Nottm_S2's Avatar
very common issue
the £15 ebay ones do the job.. i think i have done all 4 on both my S2s
to get them off is easy enough, generally just bash the old one and then grip the ball head with mole grips and spanner the rusty nut off. the oem have a hex key inside the thread but rust ensures that wont help you get them off
Old Mar 1, 2019 | 04:46 AM
Brailer's Avatar
Thanks, how long should new ones last? Was looking at getting the modified ones from teigwa with the hex nut on both sides to make it easier to change in the future?.
Old Mar 1, 2019 | 06:24 AM
Nottm_S2's Avatar
some of the ebay ones are like that too
swap is easy once the wheel is off
not sure any of my swaps have failed yet tbh.. i did one rear on my 2001 last year just before MOT and i had bought both, in the week before the MOT the other one gave up haha
the rears are easier from what i recall, all they are is a double ball joint to connect the arb
Old Mar 1, 2019 | 09:38 AM
Owd-Guy's Avatar
Just fitted the Hardrace ones to back and front , can’t say yet if they are worth the money i.e approx. £60.00 per set as car not driven since.
Had to cut the old ones off , a bit of a pain.
Old Mar 1, 2019 | 10:49 PM
RobinA3's Avatar
Don’t bother with expensive ones, cheap eBay ones will be fine and last probably as long as the more expensive ones.
Old Mar 1, 2019 | 11:49 PM
TangoVTEC's Avatar
Ditto - My eBay ones are about 7 years old and still doing fine
As others have said, many have a hex nut on the back side so you never have to deal with a rusty, cheese-soft Allen head when trying to remove them.
Old Mar 3, 2019 | 01:33 PM
Brailer's Avatar
Anyone recommend ones from eBay?
Old Mar 3, 2019 | 10:20 PM
Nottm_S2's Avatar
i fitted these last year, they have that hex nut bit
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F 292724300995
sure they do fronts too
Old Mar 4, 2019 | 01:11 AM
Brailer's Avatar
These were the ones I was looking at so happy days
trails
Nov 14, 2015 01:58 AM
Venna
May 16, 2012 12:57 AM
-McConnell-
Jan 10, 2012 12:40 PM
davidds2s2k
Mar 15, 2011 02:58 PM
