Front oxygen sensor
Old Jan 12, 2014 | 08:57 AM
ObiWayneKenobi's Avatar
Default Front oxygen sensor
EML came on recently and Honda confirmed it was the front O2 sensor. They quoted me £470 for part and fitting. Hond-R new me gave me a similar price as they couldn't import the part and would pay the same price as Honda themselves, plus they'd need to take it to Honda to have the engine management register the part.
I've done a few searches on here and everyone pretty much suggests getting a Walker part and have a go at fitting it, once you have the right socket. I'm willing to give this a go but do I still have to take it to Honda to have the part registered with the engine management? Will EML go off and stay off? I'm worried because it's not an OEM part that the car won't recognise it and keep throwing up the light.
According to Hond-R, Honda have recently brought out a new sensor as the old ones were prone to cracking, hence the increase in price as seen in previous threads on here.
Old Jan 12, 2014 | 02:02 PM
MIP's Avatar
MIP
Never heard of that. I'm open to be corrected, but I'd have thought you'd just plug it in and reset the ECU wouldn't you? Pull the fuse, have it re-learn, job done. That's what I've done on previous cars, not the s2k, but it's a four wire lambda sensor just the same as ever.
Maybe see what price Hendy could do for an OEM one: https://www.s2ki.com/s2000/topic/852...page__st__1925
I wouldn't try a cheap non-OEM unless some one on here has given it a go and recommends a particular one. Maybe a good brand like Bosh or Denso (I'd guess OEM is Denso). I tried a cheap one on a previous car and it ran like crap.
Old Jan 12, 2014 | 02:08 PM
markforrester99's Avatar
I got a Denso sensor (OEM manufacturer) for a very good price direct from the USA via ockauto. I will try and find the part number as mine has been fitted to my 2006 S2000 with no problems.
Also assuming you removed the sensor and then installed the new sensor without powering up the ECU via the ignition then you would get no engine check light, then its a simple case of disconnecting the battery for 10 minutes or so which will reset all the ECU's long term fuel trims.
Edit. I used this info on rockauto.com
DENSO Part # 2344124
You will probably get that delivered from FEDEX for less than £100 and probably have it by Wednesday/Thursday if you ordered today. The part number lists 2000-2003 but the main reason is later on the AP2 version in the states swapped over to a wideband sensor. The European sensor stayed the same narrowband as the original.
Old Jan 12, 2014 | 11:10 PM
Tegiwa Imports's Avatar
Former Sponsor
I will get you a price today, we might be able to do a good deal.
Old Feb 8, 2014 | 09:39 AM
Little update on this. I bought a Walker sensor for £114 and got the local tyre and exhaust place to fit it whilst I was having two new rears fitted for £30. Total saving = £326! Had to disconnect the battery to get rid of the EML but all is good so far. Thanks for the advice everyone.
Old Feb 8, 2014 | 12:35 PM
richmc's Avatar
If you had driven around for a while it would have reset itself, so making those dudes charging to reset it a bit of a rip off.
Old Feb 9, 2014 | 12:30 AM
loftust's Avatar
So Hond-R are basically cnuts...
Sent from my GT-I9300 using Tapatalk
Budfuser
Oct 5, 2017 11:37 AM
louis1
Nov 2, 2014 05:27 PM
ScottS2k
May 5, 2011 05:07 AM
Muzzsjm
May 23, 2010 04:06 AM
mzm70
Nov 23, 2009 11:20 PM
