Front roll centre correction when lowering... options?
UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Not sure if they will work with the standard ball joints as the standard ball joint protudes out the top of the holder only slightly but double check before you order , i have made my own 13mm aluminium bar milled to the correct shape and groved to miss the top of the ball joint, also made rack spacers all in cot me £15
Great info, that answers that then. If only I had access to some machine tools. I'm almost tempted to have a go at hand fitting some myself.
Amazed something like this doesn't appear to exist off the shelf to be compatible with the stock items. Seems everyone is happy to pay through the nose for the branded stuff.
Why don't you sell these then? I definitely need a set.
Did you so something similar for the rear too or does that not need it?
