Fuel Filter
The search has not really given me a difinitive answer...
How do I get to the fuel filter and change it? Does anyone have a guide? I saw one for a fuel pump?? Are they liknked, close?
Thanks.
Thanks.
Fuel filter is inside the boot behind the carboard panel on the left side. (you see a the metal fuel pipe leading to the tank, its somewhere near there). To change it, IIRC you need to have the roof down and access it from behind the passanger seat. Its a huge job.
I have been told that its not an item that honda change during any of their service.
Theres 2 filters, actually the one specified is more like a sock (known as suction filter) that sits on the end of the pump.
But there is another filter inside the fuel tank itself IIRC its cylinder shaped - you'll never need to replace it unless you have serious problems and for that matter the sock itself, plus the tank is plastic.
Si found this out, when i looked into he is correct, so dealers just change the sock not the actual filter - its not 100% necessary. Yes Honda have it in the service schedule, but my dealer told me they have only changed one in the past @ 100k and it didnt even need changed it was just slightly discoloured.
You remove the rear parcel shelf to gain access to the fuel tank, its sits inside the tank itself, my car has well over 100k and theres nothing wrong with it.
Note H and B.
Note H and B.
