gearbox
When changing up through the gearbox the change is not clean. Each gear seems to just snick the following gear.
The clutch is fully depressed and even on a slow change the snick is often still there. There are no problems changing down through the box.
The car has done 45K. and is a 2005 model
I have had the car just 3 weeks and it was purchased from a Honda dealer.
Have I got a major problem?
I would take it back ASAP and don't let them fob you off.
To be sure, you could try someone elses local to you. Gives you some more ammo against the dealer.
It should be a perfect / award winning gear change!
Originally Posted by 98RON,Apr 16 2009, 10:26 PM
The S gearbox is undoubtedly tight and notchy when cold. Should smooth right out albeit still in a kinda snug rifle-bolt way when fully warm
Sticking a bit in first when cold is not unusual (cured by changing the gearbox oil for me) but not all, all the time.
