Gearbox Additives- worth a shot?
Old Feb 15, 2006 | 02:54 AM
vtidan's Avatar
Default Gearbox Additives- worth a shot?
Recently I have been having problems engaging 2nd gear in my S. Mainly from cold but also after a 10-20 minute run she is still difficult to engage, particularly on the down change. I know the S box is crap from cold but this problem seems to have got worse since I had the redline gearbox oil put in the box. Where I work (motor factors) we sell "WYNNS gearl oil treatment" which says that it can reduce friction and smooth the change. Is it worth adding some to my gear oil or am I asking for trouble.
Old Feb 15, 2006 | 03:01 AM
Nick Graves's Avatar
Your double-declutching needs attention, not the box!
It is not recommended that you put these quack remedies in your carefully-formulated oil.
Old Feb 15, 2006 | 03:23 AM
mytse's Avatar
I just change my gearbox oil to redline, felt much smoother with it. Can't be the oil.
Old Feb 15, 2006 | 03:31 AM
Neil.H's Avatar
There's a known problem with the synchromesh between 1st-2nd wearing out prematurely, if it happens when the oil is warm I'd say this could be your problem.
My gearbox loosened up noticeably when I had the oil changed for some Redline, this might be worth a try before getting the gearbox rebuilt (which I believe is the fix for the above problem).
Old Feb 15, 2006 | 04:27 AM
vtidan's Avatar
I went out for some SUL at lunch time( 40 minute round trip) and gave the car some TEC and the box was pretty much spot on! I did move the drivers seat 1 click forward though last night in case it was me not pushing the clutch right down to the floor. I wonder if that would make a difference.????
GeorgieS2K
Sep 12, 2012 05:55 AM
s2000tim
Jun 6, 2009 12:52 AM
baldy2007
Feb 15, 2009 09:29 AM
frankyknuckles
Aug 20, 2003 11:50 AM
quocisflying
Aug 6, 2003 05:18 PM
