Gearbox & Diff plug washers
Old Feb 20, 2008 | 04:35 AM
bikemechanic's Avatar
Default Gearbox & Diff plug washers
What is the size (ID/OD/Thickness) and specification (copper or Alu) for the two gearbox plug washers and the two diff plug washers.
Want to get these ready for draining & replacing oils with Motul G300 & 90PA
Phil
Old Feb 20, 2008 | 04:39 AM
RedUn's Avatar
I can't remember exactly as I've never changed mine, just re-used the ones on there and it's been spot on.
They are ally washers though.
Old Feb 20, 2008 | 04:43 AM
tomkbucks's Avatar
changed mine at the weekend and used the originals - the rear diff filler is a bit of a bitch to do and needed a spanner... not a socket,
Old Feb 20, 2008 | 05:29 AM
hazdjc's Avatar
Its always best to replace the washers, don't cost lots, if you don't and they start leaking you have to do it again.
Don't know how much they cost but the bolts need to be set at:
G/Box 39N.m 29lb
Diff 45N.m 33lb
Dave
Old Feb 20, 2008 | 06:50 AM
G/Box 39N.m 29lb
Diff 45N.m 33lb
Found this info in the service manual but it doesn't give the size of the washers
Anyone?
Old Feb 20, 2008 | 08:25 AM
RedUn's Avatar
You tried Honda?
Old Feb 20, 2008 | 10:30 AM
AquilaEagle's Avatar
Administrator
it would certainly be a good place to start
or the parts catalogue
check here:
http://www.slhondaparts.com
J1122
May 28, 2009 09:57 AM
RobJ1
Apr 17, 2008 09:43 AM
Dampachi06
Apr 13, 2008 07:42 AM
junsu
Feb 14, 2008 06:40 PM
GDM S2K
Oct 21, 2005 07:37 AM
