Geo bushes...
Geo bushes...
Hi there, I Am looking to buy an S2k and have found a nice example. With regards to the geo bushes and seizing, if the bolts are seized yet the geo set up feels ok and tyre wear is even etc do they still pose a problem? I ask because the car is an early model is it more likely that they will have seized?
Cheers for any help
Cheers for any help
it only becomes a problem if you want or need to alter anything
you can not get the bushes from honda they only supply the arms with bushes fitted and these are exspensive and the front compliance bolt + coller are about £72 each on there own.
so it would be far better to know the bolts turn before you buy.
good luck.
good luck.
Running over a pothole hard can put it out and the S NEEDS correct geo, so it's important to be able to have it adjusted. If you find one you like get it to a garage and see if theres evidence of copperslip grease on the bushes if you aren't sure ask if its OK to pull one of the bolts out, if ones not greased it probable that none are, thats your cue to walk away or be prepared for a big bill getting it sorted.
You really DO want to know this has been done if mine is anything to go by, 2004 car and 82k miles.
Having never looked under an s2k before can anyone share a picture of the underside of the car so I know exactly where to look for them? The car is a 2000 with 57k am has been garaged for most of its life
The consensus is its important then, if theyare seized amd the geo is out by whatever margin how will that translate to the drive of the car, will the rear feel loose or like the car is crabbing or anything?
Hi there, if you search for one of my posts there is a big write up about my gro job with plenty of pictures. (I'm on my iPhone so can't find the thread).
I'm sure someone on here will find it for you.
Out of interest, how much have you got to spend on a car?
Andy
Andy
A lot of it is down to how the car has been used and where it has been stored. Garaged isnt always better if it has been used in the wet then put away. The only real way is to take the car for a 4 wheel alignment. Consider it £100 of your money well spent if you're serious about a car, it will pay for itself if it avoids a car that is seized solid.
