geometry
Old May 16, 2005 | 04:16 AM
jonjoe's Avatar
Default geometry
im going to have my geometry set up and I just want to know if the settings that they will have for my 2002 model will be ok or do i need to give them different settings
Old May 16, 2005 | 04:20 AM
Bassoctopus's Avatar
Get the settings out of the tech faq
Old May 16, 2005 | 04:21 AM
Fletch's Avatar
Better to be safe.
Print this off and take it with you...
From the FAQ
(feck Would be ok if the pictures worked )
jonjoe's Avatar
I don't want to sound stupid but i probably already do. Shall I get it set to thoses settings on tech or are they just for the 2004 model
Old May 16, 2005 | 04:22 AM
Nachi's Avatar
Just got back from having mine done - if they have the right equipment it should include the specs for the S.
I believe the manufacturer specs are listed in teh Tech FAQ so print a copy and take them with you just in case!
Old May 16, 2005 | 04:27 AM
Fletch's Avatar
AFAIK The ones "typed" into the FAQ are for the my04 and above. (Could be different with 17" wheels??? )
It's the settings on the scanned document that you need. (the one that we can't see because the effing site is screwed )
Old May 16, 2005 | 07:20 AM
Crusader Rabbit's Avatar
Good point just raised there..........I've got 18" wheels and just had car lowered on Eibach springs. Just waiting for springs to settle down then will be taking car in to have geo settings done as per FAQ for an '01 model.
Does having 18" wheels and/or aftermarket springs affect the geo settings that I should aim for???. Will the ones in the FAQ still apply????.
Appreciate a quick response on this as will be getting it done in next few days!.
Old May 16, 2005 | 09:47 AM
mikey k's Avatar
IIRC
Not if you haven't changed the rolling diameter
FAQ has two settings standard and optimum - go for optimum!
Old May 16, 2005 | 11:45 AM
ade73's Avatar
Mines lowered and on 18"s and i went with the ORIGINAL hardcore setting, cos im not a pussy like mike
Old May 16, 2005 | 11:49 AM
mikey k's Avatar
Plus you'll have no wheel arch liners like me
