Geometry setup help
#23
Originally Posted by CHIPPO
Indeed it could be your problem , why do people mix up tyres , I wont even do it on a mundane car
You need to sort that , sort the geo and check the calipers.
But hey will get a reo50, unseize the camber bolts, check calipers and hope for the best :-)
#24
Agian , you need 2 tyres minimum , so they have the same rolling radius , i.e tread depth, and come from the same batch , so thier age is the same and the compound is from the same mix.
I am not familiar with the tread paterns of the 2 bridgstone tyres or the constrution but i bet they differ, as a result the levels of grip and rolling resistance will differ.
#25
#27
Originally Posted by s2k_Nut
That odd tyre would defo cause a problem like you are encountering I reckon, especially as you reckon it's not under braking but on acceleration?
#28
There was a thread a while back that had "identical" tyres (same make and model) but suffered the same symptoms as you - pulled one way on acceleration and the other on braking. They discovered (at Centre Gravity I think) that they had been made months apart in different fabs so it's definitely worth sorting out if something that small can make a difference. I can't find the thread but will post it up if I find it.
#29
