Haunted S2000...
Mmmmm interesting but since I've been using it no flat battery… battery placebo?
Something is staying live as the stereo came on with the ignition off?
It's easily rectified though as I just turn the stereo off on the unit itself before turning the ignition off.
I knew someone that had an Alfa GTV back in the day which would on occasion, open its windows, flick on the wipers and/or headlamps and even start itself, all whilst in a locked state and the keyholder nowhere near the car!
That's down to the Italian crafted electrics I suspect!
Your issue may indeed be related to the stereo and the fag lighter sharing the same fuse. For both items will be sitting on the same 'side' of the switched circuit, if you know what I mean, so it doesn't matter whether the ignition is in position 2 or whatever. The charge pack will form a closed connection with the stereo that way.
We once had a Alfa Sud that decided to set itself alight and that was electric based!!!
I have got a fused permanent live connected to my base. Would this play a part in it at all?
To many spirits again
fwiw I too have a solar charger but it connects directly to the battery terminals. seems to do the trick but the car still needs a drive from time to time.
Therefore one can get an arse-circuit and anything that is live when the ignition is switched will be live if you shove voltage the wrong way up the fag lighter.
Since there is a permanent feed to keep the radio's memory, some of it might even find its way back to the battery.
However, shoving power the wrong way up FREDs is not really to be encouraged.
I tend to stick the battery conditioner on each of them now & again, so that the pulse mode will de-sulphate the lead plates as well as to top them up. I'm doing the Leg End as we speak, purely for reasons of de-sulphation.
I've just remembered the 86's battery is four years old and tiny and I've never done it...
