Headlamp washers
Is it only 2002-3 cars that have dash mounted headlamp washer switch?
Is it to the right of the steering wheel mirroring the foglamps?
Who has changed theirs to the dash, was it Bharat?
Ta
Ta
Ta
Ta
Yep !
Yep !
Bharat
Slightly off topic.
Noting my none VSA '06 has a blanking plug where the headlight washer tumbler switch use to be, my Honda dealer gave me a washer switch which I have wired up to some air horns.
Originally Posted by grantedS2k,Jun 8 2007, 06:15 PM
So how do I change the switch from the console to the dash? I have the switch already, I just need the wiring!
One of the easiest / cheapest / best mods that I have ever done.
Bharat
I figured it would be that simple... you got any pointers for me bharat? this will be my first electrical project on the car!
Are there the same amount of pins on both switches, and do they use the same colour coded wires?
So ignore the others
MY04 has this switch, although it is now disconnected as part of TSB fix thingy. . .
