Headlight auto leveller
Old Jun 11, 2013 | 04:35 AM
sound_wave's Avatar
Default Headlight auto leveller
I'm trying to get the headlights up a bit, as the spread of light coming from these headlights is poor to say the least. (I have about 1second's worth of light at about 45mph).
I'm going to try the auto leveller first - everything on it is free moving, so just need to know if i need to shorten or lengthen it to raise the beam. (Can't see the lights when I'm under the car )
Thanks
Andy
Old Jun 11, 2013 | 04:42 AM
lovegroova's Avatar
You don't need to fiddle with the auto leveller, see the attached instructions.
[attachment=40477:Headlight Adjustment.pdf]
File Type: pdf
Old Jun 11, 2013 | 04:44 AM
User 4225's Avatar
I had the same issue, use the adjusters on the back of the headlights to bring them up to a better level if the auto adujster is all free moving.
You need a long philips screw driver or an 8mm ratchet spanner with a flexi end
Old Jun 11, 2013 | 04:47 AM
sound_wave's Avatar
Thanks guys, will try this.
Does anyone know which way the leveller is supposed to move though?
Old Jun 11, 2013 | 04:50 AM
BenRNBP's Avatar
Okay, if I have my brain in gear, you want to turn the screwdriver clockwise to raise the beam.
edit
You were asking about shortening the adjuster, well if it's designed to lower the headlights with weight in the boot then shortening it will bring the lights up - not sure how much room for adjustment you have on the threaded bar though and that's if it's not seized.
Old Jun 11, 2013 | 04:53 AM
WinFreak's Avatar
Think that's right
And make sure you adjust them both as much otherwise you get a really annoying top of beam line
Old Jun 11, 2013 | 05:00 AM
sound_wave's Avatar
Thanks guys. The benefit of the auto adjuster is that I don't have to fanny about with each headlight separately.
It's definitely not seized up either. Been nailing it with carb cleaner and a tiny wire brush. Nuts unscrew nice and easy - you just have to be under the car!!
Old Jun 11, 2013 | 05:01 AM
lovegroova's Avatar
Alternatively, take it to an MOT test place - they will be able to help out with adjustment to the correct heights...
Old Jun 11, 2013 | 05:23 AM
richmc's Avatar
But then you still need to check they are both the same height first, and it's better to have the auto adjuster set to spec first then do the headlamp adjustment so then you know the auto adjuster is not going to run out of range if you load up the car. if you see what I mean, I has an advisory because one light was out, if you just rely on the auto adjuster you could be in the same boat.
Old Jun 11, 2013 | 09:39 AM
sound_wave's Avatar
Ok i see what you mean. Does anyone know what the spec should be? (Height of beam at a certain distance?)
All I can see in the manual is that the top of one should be higher than the other.
