Hello & HELP
Old Nov 7, 2006 | 01:00 PM
eSeM's Avatar
Originally Posted by pacman24,Nov 7 2006, 09:55 PM
How many times to I have to respond to get "Member" and stars?
Has anybody had any reports about rear suspension problems alignment/worn bushes/wishbones etc?
You have to pay dosh to become a member and you get a new star every year.
There is a known problem with suspension bushes siezing. If you have had a full alignment check then this is unlikely to be your problem as the seized bushes stop adjustments from being made.
Who carried out your algnment checks?
Old Nov 7, 2006 | 01:10 PM
mytse's Avatar
Originally Posted by pacman24,Nov 7 2006, 09:49 PM
they have not changed these as left/right 5'57"/5'59" (The target set up is 6'00" +0'15" -0'15"). Not sure why tread depth would affect it, but thanks for the tip.
Castor looks ok to me.
Show us the others...
Old Nov 7, 2006 | 01:18 PM
Kobe's Avatar
would a bad rear wheel balance be enough to cause this..?
or diff?
Old Nov 7, 2006 | 01:22 PM
mikey k's Avatar
with Man
Then take it to Chris
"Honda do a full alignment check"
Old Nov 7, 2006 | 11:59 PM
S2K-Neil's Avatar
NOT !!!!
(Joke of the Day)
Old Nov 8, 2006 | 12:13 AM
alex.stanley's Avatar
I need to get the alignment done on my BMW - if somebody's arranging a day do you think I'd be able to squeeze this in or would that be frowned on that it's not an S2000?
Old Nov 8, 2006 | 08:39 AM
AquilaEagle's Avatar
Administrator
Chris would be more than happy to do it I am sure Alex
Old Nov 8, 2006 | 08:54 AM
mikey k's Avatar
Don't worry about Chris he is a porker fanatic, S2000 are 2nd
Old Nov 8, 2006 | 12:05 PM
lower's Avatar
Not sure why tread depth would affect it.
The s2000 has a torsen rear diff which means it transmits power to the wheel with the most grip. If the rolling radius's are significantly different eg one tyre is low pressure, the diff transmits the power to the other side. Thus as you come of and on the power the car tends to pull to one side or the other. If you have one brand new tyre on one rear and a worn one on the other, this could cause the same effect.
However, it sounds like your alignment isn't right.
And yes, i would go for new s02's. Its only the rears that have reduced size and quantity rain channels compared to standard tyres. The fronts have full rain channels and aren't the widow makes some people would have you believe. I spent 2 winters with s02's and found them fine.
Old Nov 8, 2006 | 01:23 PM
CiderBoy's Avatar
If you can, try driving on the wrong side of the road and accelerate from 50mph.
Obviously you need to make sure you do this in a safely!
But you may find the car then pulls to the right.
Basically the car is very sensitive to road camber, so whilst you may feel the car pulls to the left, it may just be the general road camber.
Nick
