Help
I'm off to France next week so was checking out the spare. It was at 17PSi so took it to the garage and decided to check the rest while I was there. Discovered that my front tyres are nearly on the limit wear-wise. Worst thing though is that there is afair amount of cracking in the rubber around the tread.
I'm fairly certain the fronts are the originals. I got the car with 27k on it and it has fairly unused P6000s on the back.
Anyway, problem is I have to drive from London to Exter tomorrow (Tues 7th) evening so need somewhere in SW London that can whack a new set of tyres on for a reasonable price. I don't particularly mind if I replace with Bridgestones. i thought maybe P6000s as they're on the back, or Eagle F1s.
Can anyone recommend:
A. Decent tyre for the front
B. Good tyre dealer in SW London (pref. an independant)
Thanks
Thanks
No - he drives an M3 IIRC
Bracknell is where you need to go, or get Event out. www.eventmobiletyres.co.uk
btw don't mix your tyres.
