Help with CEL
Old May 31, 2007 | 05:05 AM
St.Simon's Avatar
Angry Help with CEL
Hi had a CEL recently, took the car to Honda who pulled up the codes:
P0301 7 - 1 P1399 ____ Cylinder 1 Misfire Detected
P0302 7 - 2 P1399 ____ Cylinder 2 Misfire Detected
P0303 7 - 3 P1399 ____ Cylinder 3 Misfire Detected
P0304 7 - 4 P1399 ____ Cylinder 4 Misfire Detected
This happened 3 months ago and all the plugs were changed. The guy at honda does not know what to do, he has mentioned injectors, wiring looms etc. Ive had a reset but I know its a qustion of time before it happens again. Any help will be appreciated.
Thanks
Old May 31, 2007 | 05:55 AM
Dembo's Avatar
Mine was doing "misfire" codes without anything else. Turned out to be injectors.
Old May 31, 2007 | 08:19 AM
s2kbad's Avatar
Random Misfires can be caused by a number of things. It can at times send you on a wild goose chase. Are you experiencing any of the following symptoms:
1. Rough idle.
2. A pulsating exhaust - are the exhaust gases flowing smoothly out of the exhaust?
3. Have you noticed any loss of power at low or high revs?
4. Has the car ever been mechanically over reved?
Fouled plugs can generate the codes but other things to consider are; coil packs, fuel injectors and ECU. In severe cases bent valves also produce misfire codes.
solitarycheese
Aug 16, 2014 09:07 AM
Eyal s2k
Jan 14, 2011 05:46 PM
beretta37
Jan 9, 2011 01:20 PM
macr88
Engine
Jan 21, 2010 10:40 AM
namasaya
Oct 5, 2008 09:12 PM
