Help - gearchange problems
Old Jul 29, 2013 | 11:01 PM
shari7's Avatar
Default Help - gearchange problems
Ok so drive this morning to work and slow down for the end of the slip and first and second gears are really sticky. When i push the gear stick to the left for first or second it sticks and stays there. Doesn't naturally come back to the neutral position
The rest of the gears are ok. I never skip shift an allow the car to warm up. It's going in for a service soon. Any ideas what this could be?
Thanks.
Old Jul 30, 2013 | 12:40 AM
User 4225's Avatar
Sounds like a faulty/sticky detent in the gearbox at a best guess. Does the lever self centre from the other direction? i.e 5th & 6th gear side
Old Jul 30, 2013 | 01:00 AM
shari7's Avatar
Yeah the other side is totally fine. As normal. Honda quoted 399 for a full service. The biggest one they do on the car I've been told.
Old Jul 30, 2013 | 01:38 AM
shari7's Avatar
Reverse seems to be an issue too.
Old Jul 30, 2013 | 01:39 AM
caboose's Avatar
Honda quoted me less than that for my 150k service, i also made them do some extra checks and stuff.
Old Jul 30, 2013 | 01:41 AM
shari7's Avatar
Hmmm. Will try another honda garage. The gear issue is worrying me though.
Old Jul 30, 2013 | 03:47 AM
shari7's Avatar
Could it possibly be just the gearbox fluid?
Old Jul 30, 2013 | 03:57 AM
Tim S's Avatar
It could just be the shifter mechanism. I regreased mine recently because it was becoming impossible to select reverse when hot. I found the shifter had hardly any grease on it and signs it had been regreased before, i.e. broken tabs on the plastic ring which holds the rubber boot on, and the second boot over the bolts which hold the mechanism in wasn't on properly.
There's a how-to somewhere on here or you could just get Honda to look at it while they have it.
Old Jul 30, 2013 | 04:03 AM
unclefester's Avatar
https://www.s2ki.com/home/2010/03/11...rease-shifter/
Just be aware the shifter only works in ONE position but fits in two ;-)
You can also replace the nylon bush and ball as well as the spring - freshens things up nicely.
Old Jul 30, 2013 | 04:04 AM
shari7's Avatar
Thanks tim.
I'm getting a little worried. Stirling honda are useless. 145 for just an oil and filter. Glasgow honda are quite pricey but seem to know what their doing.
