Help - gearchange problems
Old Jul 30, 2013 | 04:21 AM
Nick Graves's Avatar
The three bolts that hold the gear lever in can work loose and cause shift problems too.
But it's probably just needs greasing or the nylon bush replacing as Tim said.
Honda garages do vary in eptitude...
Old Jul 30, 2013 | 04:37 AM
shari7's Avatar
Thanks guys. It's going for a test drive and service at the weekend. The gear issue il get sorted myself depending on diagnostics.
Old Jul 31, 2013 | 12:38 AM
shari7's Avatar
The problem seems to have gone away for now. Seems rather weird. Might get it greased nonetheless.
Old Jul 31, 2013 | 01:02 AM
unclefester's Avatar
It's not as hot as it has been.
Old Jul 31, 2013 | 01:14 AM
shari7's Avatar
What do you mean sorry? Yesterday morning I had a 20 mile drive to work. At the end of the journey it was sticky. On the way back home which was a good 10 hours later it was fine. Again this morning it seemed ok.
Old Jul 31, 2013 | 01:17 AM
If the gearbox isn't getting as warm, stuff won't expand as much inside it. When did it last have its fluid changed?
Old Jul 31, 2013 | 01:32 AM
shari7's Avatar
Ahhh I see. It's been almost 10k.
Old Jul 31, 2013 | 06:18 AM
shari7's Avatar
Had a look at the clutch fluid and its pretty dirty. Once I get that changed then fingers crossed that should be it. Il be greasing the shifter regardless.
Thanks for all the help people.
schwett
Jul 4, 2005 07:52 PM
fisting dwarves
Jan 1, 2004 02:05 AM
Poindexter
Dec 4, 2003 12:52 PM
Big E
Jul 14, 2002 11:36 AM
