HELP - Start up parameters
Old Feb 19, 2017 | 04:03 AM
Flipz's Avatar
Default HELP - Start up parameters
Hi all,
Hoping the wisdom of the forum can once again help me out... My start up parameters have always been a bit rubbish (from cold) but now, after the car has sat for 4 months, it is refusing to start at all.
I'm running AEM Series 2 ECU, hoping someone can help out with advice/screen shot of their parameters on the start up map. I've done tonnes of research on this but only seem to be able to get the warm start settings spot on.
Thanks all...
Old Feb 19, 2017 | 06:23 AM
markforrester99's Avatar
The problem with start up settings is that injector size pays a big part in the percentage of additional fuel you need.
Also your battery voltage is 9.3 which is not good for cranking.
Have you got a wideband fitted?
Old Feb 19, 2017 | 06:53 AM
Flipz's Avatar
I have stock injectors and an AEM wideband. Yeah, this screen shot was some time after much cranking so voltage was seriously lacking. Is there some good way to read a log and work out what is needed? I guess the best thing is to look at the AFR, what sort of level should I be looking at for a clean start 10:1?
mikees2k
Dec 6, 2024 06:35 PM
VIXNU
Nov 19, 2012 03:30 AM
BerlinaS2Kyle
May 20, 2012 03:12 PM
s2konroids
Oct 30, 2011 02:15 PM
hippos2k
May 10, 2009 10:46 AM
