UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
I was fitting new speakers on the doors and after removing the passenger door panel found the following loose in the bottom of the door. It is about 3.5x8cm.
After significant inspection inside the door with a torch I could not see where it could clip back on.
I thought. Ho Humm. Never mind.
Workshop Manual to the rescue, but it does not seem to be pictured there either.
Brainwave. When I take the drivers side panel off I will look where it is clipped in that side of the car. Problem solved.
Took the drivers door panel off to find ANOTHER one loose in the bottom of that door. Noooooooo.
They're part of the window winding system, they stop the window juddering when moving up and down. There's a thread on it somewhere, the general opinion was that their not being fitted is no biggy, Mine are in the garage and have been for well over a year, and my windows still work just fine.
