UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Now that I'm driving to and from work in the dark, it's made me appreciate just how good the HID dipped lights are... and how poor the main beeams are - they seem to lack any real power.
I've read less than glowing (sorry about that...) reports about PIAA bulbs - can anyone suggest some better headlight bulbs? Or is there an HID high-beam conversion about? New Minis and Lagunas with Xenon lights don't appear to have projector lenses, so maybe there's something out there.
This is my major gripe with this car; the mainbeams are almost useless if you want to drive quickly at night. I changed to PIAA bulbs but all they did was make a weak yellow light a weak white light
I did have some conversations with Brian Marshall last year about putting higher power bulbs in (albeit they would not be giving a white light) but I'm worried about the heat problem which he warned about
[QUOTE]Originally posted by PWE 896
[B]I did have some conversations with Brian Marshall last year about putting higher power bulbs in (albeit they would not be giving a white light) but I'm worried about the heat problem which he warned about
New lights fitted to my 99 S2000 recently (blisters on black plastic, so warranty item) don't seem to have the allen bolt adjusters fitted to them. They were set up by Honda to pass my MOT but they have two peaks, instead of the very sharp one that existed previously! Are 2002 lights not adjustable by Joe Public???????????????? (These lights fitted are not the fully chromed versions of the 2002 yr however)
I was under the impression, and I could be very wrong about this, that there are no foglights because the headlights are so low anyway. This is also the reason why the main beams seem poor. They are too low on the ground to illuminate the road properly at any distance.
Have you checked your HID pattern at different distances? This is mine at about 15 feet with just the one 'step' which is how I think they're supposed to be. At about 10 feet further back I get two distinct steps.
