Higher temp Clutch fluid causing notchy change?
Mar 26, 2019 | 10:55 AM
Hi all, when I replaced my brake fluid with ATE Typ200 last year I did the clutch fluid with it too. I've noticed my gear changes are more notchy when cold than they used to be and takes a while longer than it used to for them to be smooth. Could this higher temp rating clutch fluid be the culprit or not make that much difference and I should look elsewhere?
Thanks
Reply 0
Mar 26, 2019 | 11:15 AM
I wouldn’t imagine that this is the case, if the gear change improves when hot maybe it’s the gearbox oil you need to look at?
Reply 0
Mar 27, 2019 | 11:37 AM
Got my gearbox and rear diff oils replaced and it was a revelation.
Get it done...
Reply 0
Apr 1, 2019 | 05:05 AM
Quote: Got my gearbox and rear diff oils replaced and it was a revelation.
Get it done...
I do them every 2 years - also re-grease the shifter and re grease the clutch fork every year
Reply 0
Apr 3, 2019 | 03:33 AM
The only thing is that you might not have bled it fully, so it's not disengaging where it used to.
Otherwise, it's the cog box.
Reply 0
Apr 3, 2019 | 09:36 AM
Giving the box high rpm"s < hold in gear>2nd or 3rd for a while<when warm>works for mine.<or just ring it through the gears>
don't know if thats helping the pump or the alignment of gear componants ect..but my shift feels better for it <as do I>
Reply 0
