Hit curb!
Old Apr 17, 2011 | 08:51 AM
dollag2k6's Avatar
Default Hit curb!
Hi, I've been on here for sum time and wanted to say thank you for all the information shared. Everything I've needed to know has been here!
Unfortunately I had a slight accident, sum one pulled out on me and I had to swerve, problem was the back end of the car snaked and hit the kerb. The camber is completely out, I had a geo done and could see there was a problem with both the toe and camber. I have replaced both upper and lower arms today but didnt seem to help? I also changed the hub but was a second hand one. The wheel still isn't sitting right? Does anyone know what it could be? I think I'm gonna buy a new hub but don't want to keep throwing money at it? I know my way around a car but I have no idea what to do with this now? Toe arms??? Please help
Old Apr 17, 2011 | 09:08 AM
leftfootbraking's Avatar
I would imagine the toe arm would be the leak point of the rear suspension during a lateral impact, so I would start there.
Old Apr 18, 2011 | 12:08 AM
dollag2k6's Avatar
I was told the hub should be the weak point? Could it even be the subframe?
Old Apr 18, 2011 | 12:09 AM
razzele's Avatar
Id say the Wishbones are designed to bend/break before the subframe gets bent. From personal experience they are weak
Old Apr 18, 2011 | 12:53 AM
dollag2k6's Avatar
That's what I thought hence I changed the wishbones.
The only things left are the hub and toe arm. Does anyone know where to get one from?
Is anyone using after Market toe arms?
Old Apr 18, 2011 | 04:56 AM
tomkbucks's Avatar
if you had the geo done could they not tell you why the car was not ' straight ' ??
Old Apr 18, 2011 | 05:19 AM
dollag2k6's Avatar
The problem is you cannot see anything that is bent? Everything by eye looks ok but when we tried to get the car sitting correctly it just wouldn't, I ended up having the camber at 0. It was the best he could do, I know there was a compromise between toe and camber.
Old Apr 18, 2011 | 05:34 AM
razzele's Avatar
Where abouts are you?
If your close your more than welcome to try a 'toe arm' of mine, I have a spare set in the garage somewhere
Old Apr 18, 2011 | 05:45 AM
dollag2k6's Avatar
I'm in south London, where abouts are you?
Old Apr 18, 2011 | 06:16 AM
razzele's Avatar
Newcastle !
