HKS SC kit topic
Old 02-26-2018, 04:54 AM
  #1961
johnckeen's Avatar
Tegiwa only do 15mm not 20mm.
I rev mine max 8500rpm and dont rev it till the oil is up to temp. I may change my charger oil soon also as its been in for a year now.
Old 02-27-2018, 01:10 AM
  #1962
Mike RT4's Avatar
Originally Posted by johnckeen
How much did it cost to get your them bored out to 70.1mm?
Because I live in Norfolk, I was able to get Matty to do it for me (he of crazy turbocharged / sequential gearbox S2000 fame), so was very reasonable (I can't even remember how much, but I dropped them off and collected them, as his workshop is 15 minutes from my house).
I was hoping that he could machine the H&R spacers or copy then to have the correct centre bore (so the wheels didn't have to be machined to allow them to be rotated), but there was insufficient material on a 15mm spacer to do this. You could probably do it on a 20mm spacer, so that the wheels did not need to be machined, but such spacers would have to be custom made, as no-one does this AFAIAA. However, if it is possible, it would be something that Matty could do no problem (he owns a machining company ).
Old 03-07-2018, 05:50 AM
  #1963
johnckeen's Avatar
Anyone know the official service interval for the charger oil? It must need replacing after a certain time/mileage?
Old 03-08-2018, 03:12 AM
  #1964
nomadicS2k's Avatar
The recommended oil change interval is 80.000 km (50.000 miles) or every two years.
Link
boys2k (03-08-2018)
Old 03-08-2018, 10:56 AM
  #1965
markforrester99's Avatar
HKS manual says
Traction Fluid Filter Replace every 5 years or 70,000km.
Old 03-09-2018, 02:32 AM
  #1966
johnckeen's Avatar
yeh 5 years is waay too long in my mind. Ill take the 2 years approach!
Old 03-09-2018, 02:40 AM
  #1967
johnckeen's Avatar
why on gods earth is HKS traction fluid £198. That's daylight f-ing robbery!!
Old 03-09-2018, 03:26 AM
  #1968
Define198's Avatar
This other recent HKS failure, does any one know if the guy was on the standard HKS BOV? and did he ever get the compressor surge when coming off the throttle? anyone able to contact to ask?
a few guys on the brz forum are starting to attribute the failure to this
Old 03-09-2018, 04:34 AM
  #1969
johnckeen's Avatar
I have the standard BOV and get flutter every now and again but my charger is fine.
I don't rev it past 8500 and never go above 3500rpm until the engine oil is up to running temperature (75-80c).
We need to look into how the cars where driven... some people aren't as mechanically sympathetic as others. Some poeple seem to think that when water is up to temp (3 bars) they can just give it the beans but that is not the case.
Also did they check fluid levels frequently, did it run low on traction fluid, did they run the charger in like it says too, 65 miles or so i believe.
There are too many variables to get a definitive answer.
Old 03-09-2018, 05:13 AM
  #1970
Define198's Avatar
Their is no warning sign before the charger dies, i thought my charger was fine too, and then it was not! Unless you have taken it to pieces to check the threads?
I leave my car to idle in the garage before it even moves, and then wait for it to warm up some more when driving before giving it any beans.
The traction fluid had not moved, only thing i did note was that the fluid looked dirty after it had failed
i have hardly even driven mine on the new charger, probably a couple hundred miles, my car has become a weekend only.
Quick Reply: HKS SC kit topic
