Honda locking wheel nuts
Old Apr 28, 2009 | 10:51 AM
mikey k's Avatar
The Honda ones are actually made by McGards
The do seem to be a bit frail with people have regualr problems.
Some I suspect are due poor practises.
I've always put a touch of copper grease on all the bolts.
Always undo the locking nut first and torque it up last.
Make sure you do torque all the bolts up properly.
Oh and if you are fitting aftermarket wheels check you don't need hub centric rings.
Running with out them when they are needed puts even more strain on the nuts.
Prevention is better than cure
Old Apr 28, 2009 | 02:04 PM
Hockenheim's Avatar
Originally Posted by oxhouser,Apr 28 2009, 10:44 AM
ok its off
drilled a couple of holes and used a chisle, it didnt split it came loose
i dont think it was thread bind i think its the mating faces binding if the tyre fitters use to much pressure on the nut gun
my advise is to back em off and fit them hand tight as soon as you have new tyres fitted. the honda lock nuts are a crap design.
I take off the wheels and take them to have the tyres replaced - no risk of monkeys jacking car in the wrong place and overtightening the nut with an impact wrench.
Harry
Old Apr 28, 2009 | 02:15 PM
Boab01's Avatar
Ultralite Internal Hex wheel nuts. I have em, they're great.
http://www.unit-8.co.uk/acatalog/S2000_Whe...ccessories.html
Old Apr 28, 2009 | 11:04 PM
hoppingdeth's Avatar
So you picked up those new wheel's then Oxy!!!
Bugger - I wanted those.
Can you send some pics when they're on?
Old Apr 28, 2009 | 11:07 PM
Bassoctopus's Avatar
Why does anyone use locking wheel nuts these days? As useless as car alarms! If you can drill them off, so can someone else. And when was the last time you heard of someone having wheels nicked?
Or maybe I just live in a nice area so don't have to worry.
First thing I do when I get a new car - bin the locking wheel nuts.
Old Apr 28, 2009 | 11:13 PM
s2konroids's Avatar
If you really want someone wheels you can knick them easily.
Old Apr 28, 2009 | 11:23 PM
Chris Type R's Avatar
I'm not sure that the MY00-01s are - they're certainly different from the later models (which are McGards). I replaced my originals for the later ones and never had any problems - IIRC they were
Old Apr 28, 2009 | 11:36 PM
aerxx's Avatar
I took my car for some tyre replacements the other day, couldnt find the locking wheel nut key anywhere so the garage used this - http://www.lockingwheelnutremover.co...exEnglish.html
It took them about a minute to get each locker off (secure or what?) so I now need to go and buy a new set. Just a thought, not sure how much the above or similar kits cost, but it defo' worked on my S2000 with the stand lockers.
Old Apr 30, 2009 | 06:15 AM
Riccardo's Avatar
I personally have seen an M5 in the best part of London's Chelsea resting on bricks! Was left like that for a couple of weeks and eventually got two smaller wheels as substitute.
Apparently Aston Martin wheels are getting nicked loads now in London (so many DB9s and Vantage's living parked on the road).
However, I agree with you that locking wheel nuts are a waste of time, especially for us on 16"ers!
Old Apr 30, 2009 | 06:27 AM
...and those of us that don't live anywhere near the capital - thank god
