idle learn procedure
Old Apr 23, 2009 | 06:25 AM
s2konroids's Avatar
Default idle learn procedure
Chaps,
After reseting the ECU do you have to perform the Idle learn procedure?, doesnt the car eventually learn idle?
If it doesnt how long do you hold it at 3000rpm's for?
Cheers
Old Apr 23, 2009 | 06:59 AM
MIP's Avatar
MIP
After I changed the battery, I didn't do anything special to get it to re-learn idle. I probably shouldn't have driven it straight away though, it did stall when I first came to a stop. Probably best get it started, just use enough throttle if needed to prevent it stalling when it first tries to idle, then just leave it for 5 mins or so.
Old Apr 23, 2009 | 07:56 AM
s2konroids's Avatar
This is a procedure in the workshop manual.
But i think it learns idle if you dont follow the procedure???
Old Apr 23, 2009 | 07:58 AM
chrisr111's Avatar
You don't.
Idle learn requires that you start the car and let it idle until the radiator fan has switched on and off twice, then switch the engine off. That's it.
HTH
Chris.
Old Apr 23, 2009 | 08:01 AM
s2konroids's Avatar
Ok thanks for that.
Old Apr 29, 2009 | 12:07 PM
MB's Avatar
MB
Member
Search or read the signature AJ!
It will learn itself, or you can let it sit for 2 fan cycles.
Thanu31
Apr 1, 2015 05:32 AM
macdaddies911
Mar 27, 2012 02:55 PM
razzele
Oct 5, 2006 04:50 PM
REV_29K
15
May 27, 2005 03:06 AM
s2000guy
Jan 2, 2004 03:27 AM
