Injectors
Old Jan 10, 2007 | 01:19 PM
  #51
Busamav's Avatar
I suspect the connctors are the same .
The US Hayabusa guys use the S2000 injectors too , due to their straight replacement for the bike , and the injectors for the Busa are world wide same
Old Jan 10, 2007 | 01:23 PM
  #52
mikey k's Avatar
Old Jan 11, 2007 | 05:11 AM
  #53
Dembo's Avatar
Does anyone know if they're top feed or side feed?
Asked a cleaning place and they don't seem to know anything.
Old Jan 11, 2007 | 05:53 AM
  #54
MB's Avatar
MB
Member
Did you not speak to Mark? :s
45 degrees ish.
MB
Old Jan 11, 2007 | 06:05 AM
  #55
Lickermat's Avatar
http://www.boxermotorworks.co.uk/Fue...orCleaning.htm
They know their stuff
Old Jan 12, 2007 | 01:24 AM
  #56
S2000_Europe's Avatar
there is a set in FS forum
https://www.s2ki.com/forums/index.php?showtopic=452880
Old Feb 13, 2007 | 01:13 AM
  #57
Dembo's Avatar
Well... woohoo! Just had the call to say the car is running perfectly. I went with new injectors from Spoon in the end for a lot less than Honda wanted, though I wasn't expecting them to take so long to arrive or I might have put a bit more effort into the cleaning approach. The Spoon ones do supposedly give a performance boost, so I decided that was worth the cost of new parts over trying to clean the old ones.
So it seems injectors can and do get dirty and/or fail. It would be nice to know why, but I suspect it's been building for some time and me running out of fuel last easter probably did no good at all.
Old Feb 13, 2007 | 01:25 AM
  #58
MB's Avatar
MB
Member
Performance boost?? Ok
Good to hear its solved though.
Injectors can block for a few reasons. I would get your fuel fitler checked though.
MB
Old Feb 13, 2007 | 02:52 AM
  #59
Nick Graves's Avatar
Normally, the biggest cause of 'dirt' in the petrol is actually water, form poorly-maintained garage tanks.
It's probably too time-consuming for the dealer to claen the fuel system properly.
I can't see worn indirect-injection squirters being a problem. A DI's a different thing.
Old Feb 13, 2007 | 09:53 AM
  #60
atomic's Avatar
jdmrick
Oct 10, 2013 07:50 PM
ximus
Apr 30, 2006 09:33 AM
