Jacking
Stupid question maybe, but my Halfords trolley jack won't fit under the sides of the S. Is there a better way of jacking from the front/rear, or are there lower jacks readily available, or do people drive onto blocks or something first? Obviously the scissor jack works, but that takes ages.
I've found this too, literally 1/4" too low for the trolley jack - The driving onto a piece of wood works nicely, or you can start jacking a bit with the scissor jack, remove it and then slip the trolley jack under before the car fully settles down again
Ta. Yes I've pushed the jack as far down as it'll go, and there's not much in it, so something under the wheel will probably do it.
What do people do for axle stands? I assume they should go under the same jacking points?
Originally Posted by simonprelude,Jan 27 2006, 09:16 PM
For the rear just lift the car on the bottom of the diff.
The front as everyone else says, start with a scissor jack or drive onto a couple of pieces of wood.
Axle stands, should go under the axles.
Originally Posted by mikey k,Jan 27 2006, 09:07 PM
Or use the OEM one under the sill for an couple of inches then do the center jack point with the trolley for the full lift!
