Jacking
Old Jan 27, 2006 | 01:19 PM
mikey k's Avatar
Rear is bottom of diff
Front is middle of front brace on subframe
axle stands can then go on the jacking points
Old Jan 27, 2006 | 01:21 PM
mikey k's Avatar
Originally Posted by Bada Bing!,Jan 27 2006, 08:45 PM
Get a mate to lift it slightly on one corner, or if you have no mates, drive a wheel onto a plank of wood for extra height.
He wont have any mates after they bend his wings lifting the car from them
Old Jan 27, 2006 | 01:58 PM
rahula's Avatar
I use the Hellfrauds one and it is pain, I have to use two planks of wood to drive on to. If I was buying again I would buy a different one as this one came bottom of the test and I agree with the conclusions.
For jacking points and axle stand positions see this:
http://www.rsharma.co.uk/caliper.htm
Old Jan 28, 2006 | 12:42 AM
cheshire_carper's Avatar
Never checked your site out before Rahula - you've put some real effort into that.
Old Jan 28, 2006 | 12:48 AM
MunkeyBoy's Avatar
Originally Posted by mikey k,Jan 27 2006, 10:07 PM
Or use the OEM one under the sill for an couple of inches then do the center jack point with the trolley for the full lift!
No brainer!!
Old Jan 28, 2006 | 02:14 AM
Pete Findlay's Avatar
I just drive up on some bits of 4x2, then whizz the Hellfrauds 2 ton special under. Saves swapping jacks and everything.
I tend to use the front and back jacking points. The only hassle I find is that they are so far under the car that I can hardly get any movement on the handle until it's a couple of inches up.
Old Jan 28, 2006 | 05:04 AM
AquilaEagle's Avatar
Administrator
I find that my Halfords 2ton Jack won't go up high enough to put Axle stands under (not on their highest setting anyway) And i need it that far up to get under!!
Old Jan 28, 2006 | 05:14 AM
Paper Lawyer's Avatar
I've considered a Sealey low entry trolley jack in the past, particularly now my car is lowered.
http://www.tooled-up.com/MicroCategory.asp...CID=29&MCID=379
Old Jan 28, 2006 | 05:30 AM
mikey k's Avatar
I thought about one of those but silly money for the no of times I'm going to use it!
Old Jan 28, 2006 | 06:01 AM
rahula's Avatar
Ian I use the the same one and can easily get the jack stands to fit under. You are doing something wrong.
See these links for reviews:
http://www.autoexpress.co.uk/product_test/...cks_budget.html
http://www.autoexpress.co.uk/product_test/...ks_premium.html
StrokerSi
Apr 18, 2014 09:08 PM
Carbon Blue
Jul 20, 2010 11:50 PM
chuhsi
37
Mar 8, 2010 05:39 PM
mah00si
Apr 24, 2008 09:06 AM
TGO
Feb 14, 2007 10:32 PM
