Jap Alarm Fob - 2 button
Old Nov 11, 2007 | 04:29 AM
Kiwi-S2000's Avatar
Default Jap Alarm Fob - 2 button
G'day Folks,
I managed to pick up a second alarm fob for my car, picture below.
My question is how do you, get it to work with my car?
Thanks in advance
Kiwi
Old Nov 11, 2007 | 01:59 PM
E4RTH WORM JIM's Avatar
Don't know if this helps but have a look anyway
https://www.s2ki.com/forums/index.php?showtopic=468434
Old Nov 11, 2007 | 11:53 PM
Kiwi-S2000's Avatar
Cheers Bud,
Anything at this point will do
Kiwi
Old Nov 12, 2007 | 01:11 AM
Bibbs's Avatar
Have you checked the owners manual?
I'd be interested too ..
Old Nov 12, 2007 | 09:36 AM
Kiwi-S2000's Avatar
Unhappy
Old Nov 12, 2007 | 10:23 AM
Kiwi-S2000's Avatar
Right here we go. (2min Job)
Instructions for getting a 2 button remote fob, programmed to your car.
The fob in question:-
And now the instructions:-
Things to remember make sure all the doors are closed (and boot is closed)
Sit in car and do the following
1. Turn the ignition switch to ON (II) Fully on.
2. Press the big button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0) Fully off.
4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II) Fully on.
6. Press the big button on the same transmitter twice. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the big button on each transmitter twice. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) Fully off and take key out to exit the programming mode.
Now you will find that both remotes work.
Things to consider, if like me you already had one remote fob, and your just adding a second you will need both fob's at the sametime to re-program to the car.
Hope you find this useful
Cheers
Kiwi
Phatmo111
Feb 18, 2008 09:53 AM
S2000_UK
Oct 25, 2005 12:50 PM
S2kNY
Jun 21, 2005 11:19 AM
s2000_nur
Apr 10, 2005 03:44 AM
Dracoro
Oct 15, 2002 09:42 AM
