J's ECU HELP Please
Old May 17, 2011 | 09:06 AM
cornpot's Avatar
Default J's ECU HELP Please
Hi....some help please. I have removed and sold my J's ECU but we cannot get it to start the car in its new home!
Engine turns but will not fire.
I seem to remember that it needs to be grounded but cannot remember from what to where!
Have done a search but can only find reference to petrol pump and immobiliser..........is this the problem and how do I solve it.
Sorry to be an old fart!
Old May 17, 2011 | 10:04 AM
Joeh's Avatar
Your post is very sketchy and hard to make sense.
Did you remove the J's ECU or did you install one. If you removed it, what did you replace it with, if you are installing it what year is your car.
If you're installing it you might have to ground the petrol pump.
Joeh
Old May 17, 2011 | 10:19 AM
loftust's Avatar
It makes perfect sense.
ISTR that it's the immobiliser pin that needs connecting to earth on the J's...hopefully someone like MB will be along shortly
Old May 17, 2011 | 10:30 AM
MB's Avatar
MB
Member
I don't have an ECU diagram to hand, but it's pin 15 for the fuel pump which needs grounding. Just have to check which connector plug...
Old May 17, 2011 | 11:08 AM
coolchrisuk's Avatar
Old May 17, 2011 | 11:11 AM
MB's Avatar
MB
Member
Plug A then
Where'd you find that Chris? I used to ahve full ones but lost them, and they don't seem to be in the Service Manual.
Old May 17, 2011 | 11:37 AM
It's in the service manual Mark - 11-15 to 11-19
Old May 17, 2011 | 03:18 PM
cornpot's Avatar
Brilliant...........Thanks guys......a fantastic response from all and even a diagram!
I'm constantly amazed at what a great forum we have here.
Old May 17, 2011 | 11:05 PM
MB's Avatar
MB
Member
OT but was that your car spotted on 5th Gear the other day? Gurston Down feaure on the Atom.
Old May 18, 2011 | 12:50 AM
loftust's Avatar
Yes, it would have been Adrian
I bumped into him on the Sunday
