J'S front roll centre adjusters with camber plates
Old May 8, 2014 | 12:18 AM
s2k_cy's Avatar
Default J'S front roll centre adjusters with camber plates
So what am i doing wrong guys??? I am lowered 1 inch and cannot get more than -2,5 degrees of camber on the front. any ideas???
installation photos
Old May 8, 2014 | 01:48 AM
sound_wave's Avatar
Why do you need that much camber on the front?! Are you going round corners all day?!
Old May 8, 2014 | 02:30 AM
WinFreak's Avatar
Might have to lower the caster to be able to dial in more camber?
Old May 8, 2014 | 02:47 AM
razzele's Avatar
Nice suspension! Remote resevoirs?
Old May 8, 2014 | 03:01 AM
mr-pitts's Avatar
I know mine isnt lowered as much as yours Razz,but Gary ended up removing my front roll centre adjusters because they were causing severe bump steer.
Old May 8, 2014 | 05:16 AM
s2k_cy's Avatar
Track car
i know that more camber = less caster and reverse, but j's says extra -2 degree of camber from the oem settings.
Nope.
i am afraid that my mechanic installed it wrong. I think they must rotate 180degrees
what do you think???
Old May 8, 2014 | 08:09 AM
flanders's Avatar
It's hard to see on the pictures which way they are offset but they should push the wheel outward for more negative camber.
Old May 8, 2014 | 11:51 AM
Tim S's Avatar
I think they must be installed the right way round - you wouldn't get anywhere near 2.5 degrees -ve on the front with standard suspension.
The J's documentation might be being a bit sneaky and talking about max -ve camber on full droop. Not like Japanese companies to overstate their specs...
Old May 8, 2014 | 01:12 PM
s2k_cy's Avatar
believe me my MY08 2-3 days ago was on OEM suspension and OEM ride height with max camber -2,5 and 5,6caster. My rear was able until -3,2 degrees camber on stock suspension.
Old May 8, 2014 | 01:52 PM
Tim S's Avatar
I raise my eyebrows!
My suspension on the same sort of drop maxxed out -1'40" on the front and 2'30" at the rear. MY00. Bloody awful handling like that I must say. Mine is purely a track car as well.
