J's manifold touching the steering column
Old May 3, 2015 | 06:58 AM
mr-pitts's Avatar
Originally Posted by S2KIP
I found another post on here suggesting an engine torque damper.
It's cheaper to put a shim in tho.
Old May 3, 2015 | 07:18 AM
S2KIP's Avatar
Easy job then? Which side would it need to go on, presuming right hand side of the car?
Old May 3, 2015 | 01:53 PM
mantecosa's Avatar
Mate, just need to shim the engine mount where the exhaust header is to tilt the engine a bit. We used a piece of metal with a slot instead of a hole, so we undid the bolt of the mount, jack the engine a bit, put the shim, release jack, and bolt it on again.
Also an engine damper will help when turning left to avoid engine moving toward the steering rack
Old May 12, 2015 | 12:02 PM
S2KIP's Avatar
Got Performance Autoworks to put a shim on the passenger side, it seems to have cured the issue.
Thanks for the advice guys.
Old May 12, 2015 | 02:53 PM
mantecosa's Avatar
easy solutions are the best! :-)
Sipha
Jul 21, 2018 10:41 AM
Suzuka_BlueS2K
Jun 7, 2014 01:21 AM
dave.irl
Dec 30, 2011 02:42 AM
Paul_J
Mar 31, 2010 05:19 AM
trivium
Jan 8, 2007 08:45 PM
