J's Thermostat and Fan Switch
Old Oct 27, 2007 | 12:51 AM
A7DY W's Avatar
Default J's Thermostat and Fan Switch
Just received my J's reduced temp Thermostat and Fan Switch.
I know the stat fits near the intake manifold and I believe the fan switch is on the rad.
Anyone fitted these and have any install tips and more accurate locations would be good.
Thanks Andy
Old Oct 27, 2007 | 01:02 AM
eSeM's Avatar
Be careful with the fan switch, it isn't difficult to break the plastic radiator
Old Oct 27, 2007 | 02:01 AM
MB's Avatar
MB
Member
Will people never learn?
https://www.s2ki.com/forums/index.php?showtopic=107050
F A Q!
Old Oct 27, 2007 | 02:25 AM
j8mie's Avatar
Piece of cake Andy.
Take the centre under tray off the car.
Drain all the coolant.
Swap over the fan switch in the bottom of the radiator.
Unbolt the thermostat housing (watch out for a face full of coolant).
Swap over thermostat (more face coolant )
Replace thermostat housing and bolt back up (thermostat will only go in one way)
Fill with coolant and bleed off any air in the systm.
Start car and check for leaks.
If happy re fit central under tray.
If you've any plans to fit Samco hoses, nows a good time
Old Oct 27, 2007 | 04:19 AM
markS2kcU's Avatar
Thermostat isn't the nicest job to do, I got drenched changing mine over.
Old Oct 27, 2007 | 06:10 AM
A7DY W's Avatar
Thanks for the advice folks, looks like I'm in for a drenching then.
Thanks for the link MB I did a search but couldn't really find much, obviously not as gifted as yourself
Andy
Old Oct 27, 2007 | 06:15 AM
eSeM's Avatar
I paid a dealer to install both.
Old Oct 27, 2007 | 08:34 AM
Amuse Boy's Avatar
Simple job - I didn't need to remove any undertrays - the thermo switch is accessible easily enough.
One word of caution - make sure you install th thermostat with the nipple the right way.
Also make sure you have two lots of type II coolant and some a 5 litre container of distilled water to flush the old coolant out.
Give me a shout if you got any questions.
Old Oct 27, 2007 | 08:40 AM
AquilaEagle's Avatar
Administrator
You must have very nimble nipples AB, to be able to install a thermostat with yours.
Old Oct 27, 2007 | 08:52 AM
Amuse Boy's Avatar
The little nip in question is very sensitive must be installed the right way up
