Knocking noise when in motion on bumpy-ish roads
Old Apr 19, 2002 | 03:08 AM
Ross's Avatar
Default Knocking noise when in motion on bumpy-ish roads
Well, I have had to put my car back into my dealer today, I have a weird knocking/squeaking noise when going over bumpy roads. It appears to be the suspension but is quite quiet unless you know what you are listening to, I have taken a mechanic from the dealer out and he has heard it, and also thinks its probably the suspension - it almost sounds like a creaky spring at times.
You can only hear it with the roof and windows up and stereo off, which makes life difficult when the weather is so good.
Hope they find it and fix it quickly - I want to test my wind deflector prototype upgrade thingy.
Anybody heard of this type of noise before - Brian (Bmarshal) perhaps???
Old Apr 19, 2002 | 04:01 AM
S2000RJ's Avatar
I get a squeek from the suspension going over speed bumps, always have
Old Apr 19, 2002 | 07:19 AM
markcu's Avatar
go faster and catch some 'air'...sqeaking not a problem then
Old Apr 19, 2002 | 07:55 AM
S2000RJ's Avatar
On the face of it, yes The trouble is that I have so many squeeks, rattles, clonks, etc.,, etc. that I fear something might drop off!
<<Makes mental note to ask whoever is following me at the supermeet to stop and pick up anything that falls from my car >>
Old Apr 19, 2002 | 08:56 AM
Ross's Avatar
Well, just picked up the car "all fixed sir, it was the splash guards under the engine, we have tightened them and put some foam inserts in to stop any further noise. The service manager has tested it and says all is fine."
So, out I go, and within 100yards off going down a bumpy road, I hear the noise!
It might be slightly better, but it still sounds like a muffled tin can being hit by something metallic.
Can't be bothered to complain immediately, but I guess it will be going back again.......
Old Apr 20, 2002 | 01:08 PM
Turtle's Avatar
Without localising the noise, it's hard to guess. Could be suspension, or the brakes.
-Brian.
Old Apr 20, 2002 | 01:31 PM
S2000RJ's Avatar
That sounds like Brian's experience with the fibre washers I have this image of foam and water rusting through the splash guard, until it drops off
Old Apr 22, 2002 | 08:49 AM
sgrant's Avatar
hi Ross - difficult to tell, since the car always makes a bizarre array of noises, but your squeeky noise under the bonnet sounds very similar to a new noise that i've been getting for the last couple of weeks.
let me know if your dealer finds it....
ta
s
Old Apr 22, 2002 | 02:29 PM
mrsoften's Avatar
Well I have not heard anything like that, my baby just bounces over the bumps (quite reasonable on stiff suspension).
Did 80mph over a serious hill the other night, scary, but it was dead straight so no real biggy. No squeaking but in 3rd gear am I really going to hear it?
Hope it gets sorted soon, like my damn rattle!!!
Often.
Old Apr 24, 2002 | 12:11 AM
Ross's Avatar
Well, theory nuimber 2 is its the bonnet catch, they have taped it up and tested and cant hear the rattle, I haven't tested yet, but they have ordered a new one for fitting today hopefully.
It certainly looks likely, the bonnet catch does move front to back, and has marked the underside of the bonnet (though I figured this was just normal) and the sound could be about right.
I will let you know - good luck in finding your own rattles
