KSport 6 Pot Kit
KSport 6 Pot Kit
Hi,
I am looking at a ksport 6pot 304MM front kit but want to keep the standard 17's if possible.
I have been sent a template with measurements but can't understand it!
Can anyone throw any light on what size spacers would be needed?
Thanks
Chris
Thanks
Chris
Print it out to scale, cut the dotted line and hold it against the hub face of the wheel, see if it clears and if it doesn't you measure how much you need to clear it
You could look at the numbers. It looks like about 55mm clearance from the disc, which is quite a lot. Stick a tape measure in there at the edge of the disc and see how much the wheel clears it by.
