KW v3 Coilover
Old Feb 27, 2017 | 10:53 PM
Kieranrob's Avatar
Default KW v3 Coilover
Am looking into buying KW v3 coilovers in the next few weeks and am wondering if there is anything else I need to buy prior to fitting them like drive shaft spacers? Am not intended going super low just a 25mm-30mm drop
Cheers
Old Feb 27, 2017 | 11:59 PM
Mike RT4's Avatar
You do not need drive shaft spacers at all - read this thread for explanation :
https://www.s2ki.com/forums/s2000-un...ed-car-693173/
Old Feb 28, 2017 | 12:47 AM
Ultra_Nexus's Avatar
Cheers
Make sure your car has a functioning adjustment on suspension. If any bushes are seized, now is the time to get them sorted so as you can get a full adjustment.
25-30mm is about borderline for steering rack spacers. When I say borderline I'm referring to a sufficiently negative handling attribute and not a mechanical reliability issue.
Spherical bearing toe arms are also an option to improve the action of the rear bump steer. The benefit will b e more pronouced on a <04 car.
You could also get roll centre adjusters (AKA a spacer between lower wishbone and balljoint.)
Remember to loosen all suspension bolts and only tighten with car on the floor as to minimise bush bind.
And after about 500 miles, get the car re-geo'ed/corner weighted as that will give the springs and dampers time to bed in.
HTH
Old Feb 28, 2017 | 02:25 AM
Kieranrob's Avatar
Cheers mate, my car is a 03 and I had a full geometry alignment done a few year ago and all the bushings were greased.
I think it would be a good idea to quickly check everything is still free before I fit the kit as that could be costly
I will have a look at the other bits you mentioned online
Thanks again
Turbo_sloth
Apr 6, 2015 12:37 PM
Nabil
May 2, 2011 03:44 PM
PJD
Jun 2, 2010 05:34 AM
08s2000CRbackinblack
Oct 15, 2009 06:37 PM
jp8ap1
Feb 26, 2009 07:49 AM
