lambda sensor problems
Old May 5, 2011 | 10:16 AM
Dan J's Avatar
Default lambda sensor problems
I am in the process of fitting a de-cat but the lambda sensor will not budge, i have used penetrating oil but no success . Ive got a proper 22mm lambda sensor socket on order to try.
Can i just unplug the sensor and remove the cat and fit the de-cat until i get it out ? or will this cause ECU problems ?
thanks for the help
Old May 5, 2011 | 12:06 PM
loftust's Avatar
Yes, you can unplug the sensor. There is a clip that secures the loom that requires pliers to remove.
Once the cat is out, you'll find that it is MUCH easier to remove the lambda sensor.
...oh, and just in case, lefty loosy, righty, tighty
You should not fit the decat without the O2 sensor however.
Old May 5, 2011 | 12:12 PM
MB's Avatar
MB
Member
You can fit the decat without the lambda, but I would definately plug the hole.
You will also get a CEL, but it will not harm the car or cause ECU issues.
Old May 5, 2011 | 01:25 PM
Dan J's Avatar
thanks for that guys , will try to remove it again when cat is off when i get the proper socket . other than that i will buy a new sensor i guess for the de-cat
Old May 6, 2011 | 06:27 AM
richmc's Avatar
Dan you might get a CEL with the decat and lamda, not a problem but you will need a spacer to get rid of it.
Old May 6, 2011 | 07:03 AM
thewiseboatmaker's Avatar
where did you get your socket from Dan...?
s2kbtos
Dec 17, 2017 03:08 PM
Daren 83
Jul 22, 2011 12:34 AM
nicku
Oct 2, 2006 05:54 PM
Ooalloems2koO
Apr 19, 2005 03:38 PM
