lamda sensor
Old Sep 3, 2008 | 12:06 PM
nashby's Avatar
Default lamda sensor
which exhaust sensoe fails the most on the exhaust?
Old Sep 3, 2008 | 12:11 PM
Napps's Avatar
my secondary sensor's not been working for about a year ...
Old Sep 3, 2008 | 12:15 PM
nashby's Avatar
does it make it run rough or gutless?
Old Sep 3, 2008 | 12:16 PM
RISLAR's Avatar
I would try a ECU reset before playing with the sensors!
Old Sep 3, 2008 | 12:18 PM
nashby's Avatar
i did an ecu reset when i put a new air filter in about 2 weeks ago
Old Sep 3, 2008 | 01:13 PM
Napps's Avatar
no it runs fine
I'm guessing you have the engine managenent light on?
Have you had the fault codes read, it should show where the fault is!
Old Sep 4, 2008 | 01:47 AM
nashby's Avatar
No i dont have a light on, it just seems to drive very flat and the exhaust tips seem to get black very quickly, it doesn't burn too much oil either, 40,000 miles
Old Sep 4, 2008 | 02:06 AM
nomadicS2k's Avatar
Go get an emissions check to see if its fuelling right...have you checked your spark plugs for deposits/carbon etc?
Old Sep 4, 2008 | 02:15 AM
nashby's Avatar
no havent checked plugs, adjusted valves the other day which made it better some were too tight
triccytriddy
Nov 11, 2010 11:34 AM
Bibbs
Sep 22, 2005 11:16 PM
Ruckus
Aug 17, 2005 12:53 PM
the dumontster
Jul 10, 2005 05:12 PM
ecnay
Oct 19, 2003 08:33 PM
