wierd vibration when idle
Old Jul 7, 2003 | 11:17 PM
ecnay's Avatar
Default wierd vibration when idle
when i start my engine, it revs to 1.5 then goes down to 200, and the car was shaking then it goes up to normal again. and when i press on the gas , same thing happen. is it because of spark plug or something else
thanks
Old Jul 8, 2003 | 12:34 AM
1FastS2k's Avatar
That's happened to me 3 or for times also. I just reset the ecu and tap on the map sensor and it seems to be normal after that. I'm not sure which one actually helps because I usually do them at the same time. Am I crazy?
Old Jul 8, 2003 | 01:34 AM
tritium_pie's Avatar
yeah, I had the car idling rough once recently as well. seemed to want to idle below 1000 rpm, but it didn't do it today. I've seen this on my other cars before and once they get warmed up it usually goes away. I'm not sure as to the cause, but I don't really think it's anything to worry about (like a bad spark plug).
just my $.02 tho-- I await the experts of this board to log in and give the definitive answer.
Old Oct 19, 2003 | 07:44 PM
Y2K1S2K's Avatar
i have this problem...except i dont know what the map sensor looks like....also how do i reset ecu?
Old Oct 19, 2003 | 08:33 PM
MattG's Avatar
This is a common problem on FTOs. On the Mistubishi FTO the problem is actually the idle speed controller (stepper motor). This is usually easy to fix just by removing it and giving it a brush to clean it off and then re-installing it. Sometimes you may need to buy a whole new stepper motor if cleaning it doesn't work.
Don't know where it is on the s2000 (I'm too new to these cars), but here is a link for the FTO, it may give you some idea (that's if it is applicable at all!)
M@
seoul2k
Mar 17, 2011 12:02 PM
02s2k01s4
Oct 30, 2007 06:19 PM
sjs2k4o8
May 9, 2006 11:15 AM
turboelan
May 31, 2004 04:20 AM
Kekoa
Apr 15, 2004 05:32 AM
