Leaking Diff
Old Jun 23, 2010 | 12:01 PM
mugen888's Avatar
Default Leaking Diff
I took my car to the TDI dyno a couple of weeks ago
where we discovered the diff was leaking oil.
I need to get this re-sealed does anyone know what parts are required gaskets etc. or can you just use gasket seal?
is it a big or small job ?
Old Jun 23, 2010 | 02:14 PM
chrisr111's Avatar
There is no gasket.
Use a high temperature silicon liquid gasket such as Hondabond (part no. 08718-0001)
HTH
Chris.
Old Jun 23, 2010 | 02:38 PM
mugen888's Avatar
is that the same for the half shafts and the shaft that connects to the prop?
Old Jun 23, 2010 | 11:08 PM
chrisr111's Avatar
No, they use oil seals.
Part numbers:
91201-PCZ-003
91202-PCZ-003 x2
HTH
Chris.
Old Jun 23, 2010 | 11:16 PM
eSeM's Avatar
Brian, where is it leaking from?
I had the local Hond garage replace a seal on my diff a few years back at a cost of around around £200. It took them 3 goes, over 3 months, to get it right. They kept splitting the seal when replacing the diff.
Old Jun 24, 2010 | 03:56 AM
mugen888's Avatar
hi steve thanks for that
it seems to be leaking from the rear where the studs go.
and near the front
Old Oct 5, 2012 | 03:09 PM
TrackStar's Avatar
Part numbers:
91201-PCZ-003
91202-PCZ-003 x2
HTH
Chris.
Is there a DIY for this? Any special tools required? I've replaced diffs and axles before, but never done anything like this. Thanks.
Bandit_287
Nov 21, 2008 06:39 AM
RobJ1
Apr 17, 2008 09:43 AM
CIVICTOS2000
Mar 24, 2006 12:51 PM
