lets talk big brake conversion :)
hi all its somthing ive been thinking about in the last couple of weeks. what are peoples opinion on them? are they worth getting over standard setup? which make is the 1 to go for? as there seems to be loads of companys offering them for the s2000.
Member
If you have a big bhp track car and are using semi slick tyres, then yes.
If you have a road car, with road tyres, i'd be surprised if you can get them to fade using OEM stuff, but some Ferodo DS2500 pads and a brake brace will improve the bite and feel.
If it's a track car, you can't get much better than Dixcel setup for the money.
Otherwise, you could argue big brakes are more for show!
But if you do want them, you will need different alloys to clear the calipers, and that can be tricky.
BBK I would go for are AP and Stoptech, maybe Brembo.
All imo
All imo
Banned
What's your budget?
My suggestion may be frowned upon but I'd go for k-sport.
Excellent customer service. Proven on around half the field of time attack cars including 800bhp evos.
Only 850 pounds for 330mm 8pot kit or 305mm 6pot kit for about 780, choice of 8 colours I believe and 5-6 different pad choices
What's your budget?
I'm running a Tarox 6 piston set up on the Front and larger rear discs and for road use they are complete overkill. For track use they are really good, but for barreling down the Alps they are excellent
They are expensive but are designed to fit behind standard wheels
Banned
Originally Posted by r8byb' timestamp='1303931699' post='20513767
What's your budget?
