Lowering the S2000
Old Jun 11, 2007 | 05:54 AM
grantedS2k's Avatar
Default Lowering the S2000
I'm looking at lowering my S (on replacement H&R coilovers), but what do I need to do in addition?
Are top hats universal?
Do I need drive shaft spacers?
Are the standard Honda Wheel Alignment specs still valid for a lowered car?
Old Jun 11, 2007 | 06:08 AM
Bibbs's Avatar
I did mine on springs .. needed adjustable rear toe arms, and rack spacers.
Old Jun 11, 2007 | 06:23 AM
Paper Lawyer's Avatar
I don't know, but we Nitron boys are running pillowball top mounts, whereas I don't think some of the alternative aftermarket shocks do. I think they will come with all the mounting kit though (I'd hope so, anyway!).
Lots of debate about hald shaft spacers - I stopped reading them months ago when I decided that I didn't need them.
Alignment specs - you still want the same (or perhaps a Center Gravity variations) but you need the bits Bibbs mentions (and in my sig - can be supplied by Center Gravity) to get the alignment spec with the lowered car.
Old Jun 11, 2007 | 07:45 AM
Dembo's Avatar
I reused the "top hats" on mine, but they did come with new rubber bungs to put in them.
But what is the top hat that had to be drilled to fit the Konis? So they may not be universal.
Old Jun 11, 2007 | 10:16 AM
mikey k's Avatar
with PL
Old Jun 11, 2007 | 11:08 AM
grantedS2k's Avatar
Whats the benefit of having a pillow-ball top mount?
Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
darksparkz
Aug 20, 2010 05:24 PM
EK9MAX
Jun 25, 2010 12:36 AM
rickw06
Jan 3, 2009 03:58 PM
Ferboi
Jul 28, 2008 12:04 PM
Mack
May 25, 2001 10:55 AM
